avant 1735
I am replacing the fuel pump (3 hose pump)on my blazer(4x4, 350 engine). I am using a precision fuel pump from O'reilly's. The problem is when I get the pump mounted there is no room to clamp on the incoming rubber fuel hose, it is right against the frame. If I do manage to get the hose on it is kinked up real bad. Has anyone else had this problem? I have looked at several fuel pumps on-line and they appear to be all the same. The only way I can use this pump is the heat the metal tube and bend it up about 1/2 inch, don't really want to do this, but I am out of ideas. Any help would be greatly appreciated.
