So I have this small 5000 or so BTU window AC in the computer room. It drains water out side like it should and it even waters part of my garden with it.. But the inside coil is always wet and it also drips water inside. Fan also sounds like it is sort of running in water. Wish it was an easy to pull out unit but it is not since it is sealed with the spray foam stuff. So I am guessing there should be a drain hole some place that would let the water go out the back that must be clogged up. So is there any way t open up the drain hole with out pulling it out and taking the cover off?
Thanks
Thanks
