bishopNlouisiana
As in another post, a family friend is going in a Nursing home and is giving his stuff away. He has collected stuff for years. People would simply give him things they couldn't use or get to work, or donate things to his junk pile.
Last week he gave me his wire feed welder.
Two weeks ago he gave me a generator with a Subaru ex27 engine that someone gave to him about 8 years ago but he just pack it away in his shop. The generator is a 5000s and it's spotless. Looks brand new.
I drained and cleaned the tank which still had about two gallons in the tank but thankfully the gas was cut off under the tank.
I replaced the plug any way and pulled the cord twice and the engine started and the generator started working, but.
The engine was running full blast and I could not slow it down so I shut it off.
I pulled the air filter case and noticed the speed control level has no cable going to it.
There are cables missing and two cables not connected. I downloaded the EX27 parts and service manuals but the drawings don't help.
I was hoping someone here has an Subaru ex engine on something and could help me ID what's missing in the linkage.
I don't know how to slow it down before it burns up.
I took the filter off and you can see two linkage are connected to the governor and carb that look right, and two linkage that are connect to the governor at on end but just hanging at the throttle and carb.
I took a photo I hope someone knows where the linkage goes and what on the throttle is missing.
