father's day gift
SDMike
The kids and the Mrs. came through yesterday. I have been wanting one of these for a couple of years now. Just need time to try it out.
Mike
I got one a couple years ago after wanting one for a long time. They are so so as far as how they work. The quality of the pipe makes a lot of difference. If you have trouble with the pipe kinking, fill the pipe with sand. They are not tubing benders and wont work well for that unless you buy the dies for that. I also found that it helps to keep from flatening the pipe at the side pins if I cut a short piece of the pipe, about 3" or so, and split that in two and lay it on the pipe so it's double thickness under the pins.
