Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Toro Timecutter
Stephen Newell
06-19-2017 06:35:08
Anyone ever install an hour meter on one? The model I bought didn't come with an hour meter and I was trying to install one and have run into a problem. There is a place for the meter and a wire for it but the brown wire in the harness which is suppose to be positive has no power. I know there is power on the seat safety switch which is on the same line. Am I doing something wrong or does the mower need to go back to the service department?
RobCons
06-19-2017 15:47:50
 Re: Toro Timecutter in reply to Stephen Newell, 06-19-2017 06:35:08
My old Timecutter did not have an hour meter either. Never installed one but that mower was used lots for 11 years cutting several acres. Never had many problems out of it except the pulleys on the deck. The B&S motor finally started burning almost as much oil as gas so I sold it last year for $400 and upgraded to a Toro Z Master commercial unit. The Timecutter was a tough mower.
Robin Hood
06-19-2017 12:19:33
For what its worth, I bought a Hustler zero turn a few years ago - came without an hour meter. Found out when I bought a meter for it, it was a"plug and play" hook up. Wondering if yours is the same?
Stephen Newell
06-19-2017 12:49:28
 Re: Toro Timecutter in reply to Robin Hood, 06-19-2017 12:19:33
Yes it was a plug and play. They made a spot for it in the frame and wired a plug for it but left it off. It just turned out the meter I bought was defective. The wiring confused me as it was connected to the seat switch which turned off the power to the hour meter unless you were sitting in the seat. It was a cheap meter I got off ebay for about ten bucks.
Russ from MN
06-19-2017 08:55:51
Kind of ironic a machine called a timecutter would come without an hour meter!
Stephen Newell
06-19-2017 10:02:19
 Re: Toro Timecutter in reply to Russ from MN, 06-19-2017 08:55:51
That way they can bring the price down if they don't include that accessory. Personally I think they could have skipped the switch in the seat that cuts the thing off if you get off and pick up a stick.
Russ from MN
06-19-2017 14:10:56
 Re: Toro Timecutter in reply to Stephen Newell, 06-19-2017 10:02:19
I'm sure they can't sell them without the safety features, everything has to be idiot proof, we have a growing number of idiots!
Stephen Newell
06-19-2017 14:54:51
 Re: Toro Timecutter in reply to Russ from MN, 06-19-2017 14:10:56
True True but I don't think anyone is going to trim their hedges with a zero turn.
Eric in IL
06-19-2017 06:49:46
When you checked for power on the brown wire, were you sitting in the seat with the engine running?
Stephen Newell
06-19-2017 09:58:50
 Re: Toro Timecutter in reply to Eric in IL, 06-19-2017 06:49:46
OK I got a couple lengths of wire and ran out from under the seat and while sitting in the seat the outlet for the hour meter does have power. Apparently the hour meter I purchased was defective.
Stephen Newell
06-19-2017 08:08:14
No you can't get to the wire under the seat sitting on it but I had the motor running. I guess I could make a length of wire to extend it out where I can get to it. What caused me to checking the wiring is I completely wired in the hour meter yesterday and used the mower for a half an hour and the meter didn't work.
