Ted in NE-OH
I would like to see pictures of how you store your "C" clamps. I have a lot of C clamps from small to big. I hang them on nails on the wall but they bend the nails and fall off.
Clamps are one of those things it seems you're always one short, or the one you have needs to be a quarter inch bigger! I hang smaller ones on pegboard hooks, and larger ones on nails--LARGE nails--60D spikes or similar--often drove into a scrap 2x4 that's long enough to span 2 or 3 studs to give more support. Another way for hanging clamps is that like most people that dabble with welding, I've got lots of old rod lying around, which gives me a great source of 1/8" (and of course other diameters, but 1/8" is probably the most common) round rods, which I bend into hooks and hang stuff, including clamps, from those.
(quoted from post at 18:18:59 06/17/17) I would like to see pictures of how you store your "C" clamps.
No, you wouldn't! :lol: Years ago, when I had a "real" shop, I had a place for everything. Now.....never mind.
I took a 1X6 pine board and screwed it to the rafters with spacers to make it about 6 inches down from the ceiling. I clamp wood "Jorgenson" and sliding quick clamps and C-clamps to it. On the end of our welding bench at SCSU we use a 1/2" rebar along one end to hang the C-clamps on. Jim
I ordered aluminum strips off eBay and bolted them to the side of the garage door supports . All clamps get clamped down to those strips.
You need some real nails, 6 - 7 inch spikes a couple of inches into a stud.
I hang 100 foot air hoses, tire chains, jack stands etc this way.
Shoot that's easy. Does you work bench have wooden legs? maybe 4X4 but 2X4 work.
You could even build a rack out of 2X4's with multiple levels. Cut 1/2 inch galvanized pipe the length of the uprights on the rack or the distance between the front and back legs of the bench. Then drill holes the pipe will fit through and your done. The "c" clamps hang on the pipe. If the clamps are screw type make a double hook from clothes hangers and hang em that way.
Here's some of mine.
Mine go in 2 - 5 gal buckets.
Too many clamps and not enough room.
Just added 2 more yesterday , Williams 403 and 403S.
Our welding bench has a piece of flat steel on the end that the clamps hang over...at work I clamped a piece of 1x1x 1/4 angle iron on a safety barricade so the iron sticks out over a small table, the large clamps (and a couple small) hang on that, small ones go mainly in a bin.
(quoted from post at 21:18:59 06/17/17) I hang them on nails on the wall but they bend the nails and fall off.
Use bigger nails?:D I have a window in my shop that is basically unusable. I put enough 2x4 welded wire fencing to cover the window. It makes a good hanger for all my C clamps plus a myriad of other tools. No reason you could not do that with a couple of 2x4 studs with the wire fixed to the 2in. side(as big as you want) and use it to hang all kinds of stuff from.
Noah W
