G6 at Snook, TX
Do any of you have experience with the Kohler Command motor in the Ranger or Bobcats and overfilling the gas tank. I filled mine up a couple of days ago, and went to crank it today, but it acted flooded, smelled of gas, and I immediately shut it down. I tried to restart, but the starter seemed to be in a bind. It is an original battery, but with the overfill warning--which I knew of and tried to avoid--what is the next step? I have consulted the manual and it simply warns--don't overfill! Drain oil? Gas? Did gas get to the oil and cause the starter to drag? This is on a Lincoln Ranger 250. The Kohler serial #4305401081. About a four year old rig.
