Adjusting Drive Belt on a Craftsman Model 536.773400
wsmm
Can any one tell me how to adjust the Drive Belt on a Craftsman Model 536.773400 Highwheel Weedtrimmer? The advice in the user manual is to let Sears fix it, I think not.
Thank you for any and all help.
Bill
Hello wsmm,
I am not familiar with that model, but most systems have an idler with a center bolt that you loosen and
add tension as needed before tightening. Sears lawn tractors are that way. Bet you have the same setup,
Guido.
There is no adjustment for tension, there's a spring on the end of the engagement cable supposed to keep tension on the idler pulley bracket.
Maybe time for a new belt, just replaced ours after 5-6 years of use.
Fred
