farmall100
Hello all, I spent the afternoon doing brakes on my 2007 gmc canyon 2wd. What a nightmare. Any other vehicle I have every done rotor comes off after taking the front wheel off. On this truck I had to unbolt hub assembly from steering knuckles and beat them apart. then unbolt rotor from hub. Any how my question. hub to steering knuckle bolts had yellow thread sealer on them. What is this and should I use something similar upon reassemble. and should these bolts be torqued to spec or just "dog tight" as my father used to say. Rotors are at Oreilys for turning and it will be Tuesday before I get back to reassembly. Thanks Charles
