Stan in Oly, WA
I got good advice here about protecting the carpet when painting baseboards, but I wanted to see if I could find a way that didn't require finding and cleaning materials I had on hand. YouTube had many videos on the subject, and most of them use this method: Put tape (masking tape, blue painter's tape, clear packaging tape, etc.) on the carpet along the baseboard running a small amount up onto the baseboard. Then, using a putty knife or something similar, or your fingers, push the rolled up edge of the tape down off the baseboard and around the edge of the carpet. You may be able to push the edge of the tape under the baseboard, but that didn't work for me. When I tried to use a putty knife to push masking tape under the baseboard, the tape would stick to the putty knife and pull out again. I found it easier to push the edge of the tape down around the edge of the carpet with my fingers. That was good enough for about 99% of the baseboard. After painting, you have to pull up the tape in 30 to 45 minutes so the paint won't pull off the baseboard where it has bridged and dried. The 1% which didn't work was in places where paint ran over the tape (from not being pushed down completely over the edge of the carpet, I suspect) and there was paint on the very edge of the carpet when the tape was pulled up. It was easy enough to put the blade of a taping knife between the carpet and the baseboard and clean the barely dried paint from the carpet with water and a clean rag. There were also two small places where the paint had dried too much (I left the tape in place for almost an hour in a hot room with a dehumidifier running) and pulled dime sized pieces of paint off the baseboard. That's also an easy fix.
Here's a link to a YouTube video where someone uses clear packing tape to tape off the carpet. She has good luck with it, but I didn't when I tried it, so I used masking tape instead.
Taping carpet for painting baseboard
