LAwn Trator Differential Update,
guido
Hello
Got it done it done and delivered. The differential manufacturer provided 4 mounting threaded holes. Troy Built revised the mounting, and used only two anchor points. The bolt were finger tight at best, and the X member the bolted to is was in tree pieces. But it lasted pass the warranty!
Here is the picture of the differential mounting holes. That is a crack too! The hole is the I already posted is on the other side,
Guido.
Guido,
Want more differential work? I have two neighbors, their HST diffrential won't work and I refuse to work on them. Not really sure if there are any serviceable parts on them, just replace. I don't want the job, do you?
geo
Hello,
It's the other way around: you first pick up, then deliver.
HE! HE!
Guido.
Hello Geo-TH,In,
Yep, so you can send my way. Just a hobby for me. Here is some pix. First one is the totally cracked X member..,
Guido.
