guido
Hello
Got it done it done and delivered. The differential manufacturer provided 4 mounting threaded holes. Troy Built revised the mounting, and used only two anchor points. The bolt were finger tight at best, and the X member the bolted to is was in tree pieces. But it lasted pass the warranty!
Here is the picture of the differential mounting holes. That is a crack too! The hole is the I already posted is on the other side,
Guido.
Guido.
