Hi Guido, "More oil in the mix is not the answer, as you already found out, 40 instead of 50 to 1!" Would you clarify that please? I was using 50 syn and the manual said to use 40:1 didn't specify dino nor syn. It also said 89 octane gas. Since Stihl sells syn plus storage additives in their private label engine oil, then there must be a reason. I don't see the problem with running 2.7x1.5 = 4 oz of oil to 127 oz of fuel vs 2.7 oz. That's a change of 4/2.7= 50% but an octane change of 87-89 would be 89/87= 2% if I went with the recommended 89 octane fuel. But I didn't see that as a need either....see comments below. I use 87 in everything around here including my 90 hp 2 stroke OB which doesn't care if I use 87 or the recommended 89 and it's stated (serv. man.) min compression is 120 psi. Octane increase prevents preignition, detonation of the fuel air mix prior to the spark origination causing piston top damage, probably skirt slapping damage, cylinder wall scoring below the ring groove (2 stroker) which shouldn't matter.....remembering the 10.5 compression engines back in the 60's power race between auto OEMs requiring 95 [I think it was then...R rated or M rated, not (R+M)/2 as it is today]. I read that preignition burns holes in the top of pistons. Had no such deformation nor visual indication of any piston pitting in the crown. The chain saw spec in the manual on compression min is 90 psi so I suppose the string trimmer would be about the same. Considering 14.7 psi atmosphere that's only a 6:1 compression ratio. The 10.5:1 of old days would be up in the 150+ psi reading. So I don't follow you on more oil lowering the octane to the point where you would have preignition. What's that got to do with ring/cylinder wall wear. Would think just the opposite....take it to the limit....what would happen if no oil were used? I know. I helped to overhaul a neighbor's 1949 Mercury 110 hp flat head V8 when I was a kid and we put it together dry..... .obvious results. Going to stop here and wait for you to come back. I'm interested in what you have to say and supporting evidence. I don't have a heavy background in small engines, or any for that matter. A few exceptions, like getting 4 kids through "rent-a-wrecks" and a few tractor restorations, but mostly just keeping all my stuff running, which usually didn't take much effort, over the years which was quite a bit but not like doing it commercially.
