Rebuilt my 1st alternator
Bret4207
Well, I finally tried rebuilding an alternator. Took a bad 10si Delco and turned it into a single wire, self exciting alt. Why I didn't do this years back I don't know. Simple, simple, simple. It's all parts swapping as long as the major components are good. $10 vs $80!
15 years ago the alt would go bad on the 89 Olds every year. I'd go to the local auto electric and pay $180. After the forth time I got fed up and took it apart myself. Turns out they never applied the $.10 of heat transfer compound between the voltage regulator and the housing. After a $20 regulator and $.10 worth of compound, it's still good.
FYI: Those self-exciting regulators don't last as long as the old-fashioned type, so you might want to keep a spare in your toolbox.
When repairing car radios that stuff was called heat transfer paste.
Grey color and kinda like tooth paste. Trouble was it would dry out
after a while and loose heat transfer. The newer stuff is a very thick
silicone grease. Works just dandy.
(quoted from post at 03:15:46 04/21/17) 15 years ago the alt would go bad on the 89 Olds every year. I'd go to the local auto electric and pay $180. After the forth time I got fed up and took it apart myself. Turns out they never applied the $.10 of heat transfer compound between the voltage regulator and the housing. After a $20 regulator and $.10 worth of compound, it's still good.
When that paste first came out it was $30 a oz :shock:
I learned how to rebuild those alts around 1973/74. The top gun in the shop I was working at always got those jobs. The top gun was on vacation I told the boss I can do'dat so he let me have at it. I fought it for quite some time it would not charge, Boss got fed up and orders a reman alt. I did not remove the rectifier just bent the copper tabs up and ohm checked them it checked good. That night I removed the rectifier and found the screw that goes threw it non insulated retifier to case has corroded into. From that day on I always take the rectifier out. To make maters worse the next one he let me do same deal it would not charge every thing check good. I found the rotor bad and learned the trick on how to test them with a small battery charger. Down the road one came into the shop a new replacement reman it was a cheap arse car dealer. This was on a Saturday all the parts stores closed he had the car sold I fought that alt for quite some time every thing checked GOOD. I finely found the pulley was not thigh enoufh.
When someone states how EZ this is there arse just aint got bit yet...
I don't understand the attraction of one wire alternators. They are a
compromise at best and require rpm to work. May as well run a
generator, as most tractors don't need the amps anyway. It's not that
hard to wire a 3 wire Delco as it should be. Then it is more reliable
and charges down to idle.
(quoted from post at 09:57:09 04/21/17) I don't understand the attraction of one wire alternators. They are a
In this particular case I'm replacing a 1 wire with another 1 wire. It makes little difference to me if it's a 1 wire or 3. Just happened to be what I was working on.
Just located pre-made diodes to prevent back feed! Ain't the internet great!
(quoted from post at 08:52:07 04/21/17)
I'm sure I'll run into an alt where I'm going to be busted, but for now I'm a happy camper.
I have a 1 wire on my Oliver 1600 starts charging just as soon as the tractors starts at regular RPM its a gas so I need additional wiring for switch but on a diesel all I'd need is the one wire to the battery and and a start button.
My one wire alternator on my Jubilee starts charging while it's still cranking, as shown by the ammeter.
