Rubber bumper
fixerupper
McMaster Carr calls it a rubber bumper so that's what I will call it. I am looking for some round solid rubber bumpers one inch in length and one inch in diameter with a 5/16X18 threaded steel insert in each end. Mc Master has these with a threaded insert in one end but not both ends. In other words a 5/16" course bolt threads into each end. These are vibration isolators for the control panel on an old military generator I am working on. Do any of you guys have an idea as to where I can search for these? Thanks
Try "vibration dampening sandwich mount" at mcmaster or wherever. Lots of styles available.
How about a metric rubber mount for a Honda water pump 68311-YB3-K80
McMaster Carr has just about anything you will ever need the problem is knowing the correct name for something. Next day delivery
is fantastic and 3-d models for cad design works great.
The two studs are not connected thus isolating vibration . Rubber bonds the two sides whereas a bolt would just be a solid mount.
