Long 610 parts book
Hello was wondering if anyone has a long 610 parts manual. I need part number for the bearing in the final drive. I found the one for the axle but there's 2 others that the shaft sits in that I can't find. Thanks.
Mine is 4 wheel drive. Looking for part numbers for the bearing in the rear final drives. Axle bearings and the planetary gear bearings thanks.
Book shows no planetary drives, but gear reduction drive at axle ends. Shows three different types, some bearings have the same #s, some don't. All clear as mud to me. Any #s you can find on what you have apart?
