guido
Hello
Most of the times I can use a toothpick or wire. The starter I am working,Briggs&Stratton 18 h.p.engine, has no holes to cage the 4 springs and brushes. I can put a pin or wire in front of the brush, but nothing on the other side to keep the pin straight, and the brush and spring caged. What trick or fix you guys use?. Two more hands may work on a big starter, this one is for a small one. Any tricks out there?
GUIDO.
GUIDO.
