CNC Mill X axis switches
David G
I got the X axis switches mounted, but will have to remake the bracket based on what I found. There is a home switch on the left, then an over travel switch on either end. The left over travel switch was set back 1/4", but I found out the home switch does not have enough spring travel to allow that compression, so it really needs offset by 1/8". I am going to do the same thing on the Y axis, so best off learning it now.
