While working with Knob & Tube wiring between the first and second floor I found a different type of wire.
It's two wires, twisted, cloth covered green with small red identifiers. Each wire is about the same outer size as the 14ga K&T, but is soft and flexible.
Small insulated staples are used every few feet. I don't know where it originates or ends. One wire was cut open and soldered and taped to another twisted pair to go off somewhere. The remaining wire remained intact and the excess was just looped out of the way.
It is energized, but I don't know the voltage. I don't have a picture yet.
Any thoughts as to use and voltage?
Thanks
Thanks
