I have an oil fired boiler in my basement with baseboard heat--this is a pressure system. I am installing an outdoor wood furnace--NON PRESSURE SYSTEM. Using a PLATE EXCHANGER to keep the two water systems apart, but able to fire either system.
Does it matter where I install the PLATE EXCHANGER----Can it be anywhere between the two systems??? Or does it need to be close to the oil fired boiler in the basement. I would prefer to install on the ground level floor in the attached heated area in the garage.
