Bob Bancroft
Location
Aurora NY
In the early 70's, when I started working in a shop and buying tools, I bought some square/eight point, as well as some little 12 point sockets, for driving taps.
I just learned this week that you can buy tap sockets. They are deep, with a ring to hold the tap from falling out.
How long have these been available?
A long time! I two or three. Each one works on several sizes of threads. I bought them to use with my air ratchet to clean thru threads like wheel hubs. I have never used them to cut new threads.
I have also had a set for at least 15 years. I use them mostly for small taps and light gage material. I also chuck them into a cordless drill if I have to make a lot of 1/4-20 threads in some 1/8" stock.
I welded an old socket on to one of my tap wrenches, works for me. but a tap socket would work in tighter places.
I just bought a set a year or so ago, and have used them several times for difficult to reach places. Should have bought them years ago. Got mine from McMaster Carr.
Moresmoke, Thats what I do to, and use an impact on the tap
Are you serious that you use an impact on a tap? A tap is to be turned forward for a bit then reversed to cut the chip. Chasing threads you use thread chasers to just clean up threads. Do you start bolts with an impact too?
I am very serious, I have a lot less breakage,(hardly any) and nicer threads, Havent you ever seen a CNC machine center tap? or a Tap head on a drill press? I have tapped a 4 in. 4 tpi in a lathe and didnt back up till it was done.
