I got both the X and Y motors mounted.
The steppers have shafts on both ends, I needed to make an adapter so I can put the crank wheels back on. The motor shaft is 14mm, the cranks are made for
16mm shaft so had to make an adapter. I could not get a 14mm reduced shank bit locally, so tried a 35/64, but it is just a few thousands too small. I have to get a
bit before I can finish.
I am posting pictures of the two motors and the adapter for the crank wheels.
