email poblems
cb
I am using outlook office for my email.it has so much junk on it that it drives me nuts. can anyone tell me if there is a way to delete some things that does not effect receiving email, or a more simple way to get the email'' thanks
About all you can do is change your email address from time to time. The spam you don't want it doesn't help to block it, they can get around it and be back the next day.
add the unwanted emails to a block senders list. Probably right click on email and the block senders list will show up.
I use Mozilla Thunderbird for my email, and once I mark an email as junk, it sends everything from that sender directly to the junk file. Every few days I give the junk file a quick scan to make sure there is nothing there that was good, and delete it all.
that was quick response, i'll try doing that. maybe it will get rid some of the junk. also it might help if I half way knew I what I am doing thanks
(quoted from post at 18:44:08 02/03/17) I use Mozilla Thunderbird for my email, and once I mark an email as junk, it sends everything from that sender directly to the junk file.
I had the same problem John , I started using Mozilla on advice from here . Never looked back .
cb,
There are some detailed Microsoft Office Support instructions for junk mail at:
https://support.office.com/en-us/article/Help-keep-spam-out-of-your-Inbox-in-Outlook-com-a3ece97b-82f8-4a5e-9ac3-e92fa6427ae4
Also has some good tips for avoiding junk mail...if you scroll all the way to the bottom of that web page.
Hello cb,
You can set the filter to zero or 100% junk , so all mail is junk! THEN monitor your mail a click on the ones you want to keep. That worked for me,
Guido.
thanks for the help, one other question/problem...some of the emails , I cannot open..when I click on the email, it says I cannot open because there is no previewer installed. I guess I need one thanks
