Lovingcreek
I recently installed a new clutch, PP, TO bearing and Pilot bearing on my 1955 Ford 850. I noticed the clutch fork shaft had some slop in the shaft bushing where it goes out through the case. I want to replace the bushing.
My question is how to remove the STEEL PIN that holds the forks to the shaft, so I can slide the shaft out of the case.
Any instructional guidance or experience would be appreciated.
PHOTO of CLUTCH SHAFT:
http://i756.photobucket.com/albums/xx203/pomester/IMG_0703_zpsvyrtcpin.jpg
