TractorLinks.com
Tool Talk Discussion Forum
Homelite chain saws
Angle Iron
01-09-2017 18:31:32
Homelite XL12 and super XL Automatic oiler Both of these saws leak fuel from the bronze vent filter in the fuel cap. I understand that their should be a duck bill vent installed in these fuel caps. I have seen some of the duck bill on line for sale but can't picture how they fit or stay in the fuel cap. If anyone is familiar with these please let me know how the attach. Thanks
Angle Iron
01-10-2017 13:44:14
 Re: Homelite chain saws in reply to Angle Iron, 01-09-2017 18:31:32
I only need 2 for now so will test one. It doesn't usually take long to start getting soft or sticky if they can't take it. I try really hard to not use ethanol fuel in any 2 stroke stuff and normally have little to no trouble. Both these saws were gifted to me as non runners by people who know I play at fixing small engines as a hobby. Some work out some do not
Bret4207
01-10-2017 11:32:03
Avoid ethanol fuels in your mix. If the duck bills are old stock or not made to tolerate it, ethanol can turn them into gummy worms.
Angle Iron
01-10-2017 10:23:30
I removed the brass vent filter and found the melted gloppy remains of the duck bill vent where you said it would be, thanks . I have ordered the ones off e bay I believe they were 5 for around $11.00. Will update when they come in if I can remember that long.
Angle Iron
01-10-2017 05:34:43
Quoting Removed, click Modern View to seeThanks for now, I will look into it later on today and ley you know what I find. What you are saying makes sense in so much as I have looked at several on line new old stock and used and all are like mine with no duck bill in sight.
Angle Iron
01-10-2017 04:27:09
[quote="CVPost-Den N Ms"](reply to post at 21:10:25 01/09/17) [/quote Den N MS from what I understand there is no vent in the tank just in the fuel cap, these duck bills are the ones I have looked at.
Bob Bancroft I will look into the removal of the brass filter and see if that is the case with these. Are the duck bills that Den M MS linked the right ones?
Bob Bancroft
01-10-2017 05:31:09
 Re: Homelite chain saws in reply to Angle Iron, 01-10-2017 04:27:09
Hard to tell size by looking at the picture. As I recall, the Homelite duckbill was about 1/8" diameter.
Bob Bancroft
01-10-2017 03:08:46
The duck bill is in behind that bronze piece. Pry it out, replace duck bill, press bronze back in.
Den N Ms
01-09-2017 20:10:25
Angle Iron,Is there a hole in the fuel cap for a duck bill or is it the one on the gas tank just sticks in the hole, located on the side of the tank up at the top.
jack345
01-09-2017 20:09:10
Yeah, they just slip over the pressure hose coming from engine block . They do seem to fall off after time or a good pop of engine starting. I've tied them on with very small wire..it seems to help.
