83 Suburban safety switch Update
GaryinKs
Still can't get the suburban going, battery tests 12.5 volts, all the cables are clean, starter has always worked good, just had to hold the shift lever all the way to the left to get it started, now nothing. There are 4 wires coming out of the neutral safety switch, an orange and white on one clip and a purple and blue on the other, which 2 would I have to hook together to bypass the switch? the blue and the purple? thanks for all your help and Merry Christmas
Finally got this figured out, someone had done some of their own wiring at one time , thats why this was so confusing, thank you for all of your help.
