Well yesterday the air pump rebuild kit came that I ordered. Before installing the kit I drained the tank and flushed it and added fresh kerosene. I also checked both the air line and fuel line for cuts or obstructions and cleaned the tank pick up filter. Then I installed new pump kit and filters. It runs a lot better now and will keep the nose cone nice and red. I am still not building the right pump pressure though. It should be 8.5 max. And with the adjusting screw maxed out I am a little over 6. Seems to be running fine with little fumes and making a ton of heat.now I can't figure out why my pump pressure is still on the low side after going through everything two or three times. Heater is usable but not 100 percent. Thanks for everyone's input. Tried a new nozzle to and that made no difference.
