Looking at electric baseboard heater. Question is. Two heaters have same output wattage. #1 is 120v, #2 is 240v. #1 uses 8.3 watts, #2 uses 4.1.
Is the 4.1 per leg/line so would equal 8.2 or is it only 4.1 together? Can't see how it would use half the power to produce same BTU. If indeed 4.1 for both lines together it would cost half as much to run, right? Thanks for the help. Bob
