Adirondack case guy
Over the years I have used several tools to cut steel. Tin snips, to nibblers, to wood cutting blade backwards in a 7.25 circle saw for light gauge steel (20 gauge and lighter.
Years back when I was building steel freespan buildings, I bought a Frued Diablo metal cutting blade for my Porter Cable circle saw. I have no idea how much steel this blade has cut, but it is still going strong as I fab up my new trailer. I use it on sheet steel up to 1/8" thick and it works great. You do need a good full coverage face shield though, as hot chips fly everywhere.
I also have a 20 year old 14" Ryobi chop saw, a 7" grinder that I use up the blades warn down from the chop saw with, and a 4.5 " grinder with cutoff blades for more precision cuts. (Yea-Yea, the big angle grinder can be dangerous with a 10" blade in it, but I respect it's power and what could happen) Been useing it for 10 yrs now with no mishaps, cutting steel peices that I can't get on the chopsaw. When the wheels are too small for the 7" grinder, they fit onto the 4.5 grinder with an arbor bushing to use them up.
Loren
Loren
