Re tap a hole
ldj
Today I needed to tap threads in a hole. By mistake I picked up a 3/8-20 tap instead of a 3/8-16, I suppose I had it from working on British motorcycles years ago. When I realized finding a bolt like that is hard to find and really didn't want to re drill for a 7/16 I run a 3/8-16 through that 3/8-20. Threads look pretty good and bolt will torque down. Should I leave it this way or drill and tap to 7-16. Not critical, holds bumper on VW Thing. If it failed worst would happen is it might start rattling since there are 8 bolts holding.
Make bolt on lathe with any thread you want/need. Easy way, cut threads off of longer bolt and
rethread on lathe to what you want. Everyone needs a lathe, or a friend with one. Then things like
this are not a problem, but interesting.
You answered your own question " threads look pretty good and bolt will torque down" . I'm thinking the depth of pitch may be less for the 3/8 -20 than the 3/8-16 and not much damgage was done.
