fourbright
New User
I am replacing all gaskets, seals, new lift cylinder on a 1954 Jubliee. Here's the issue that I need help with.
All pictures and videos that I've seen have bolts through the lift plate to lift pump, but mine has dual threaded bolts through cover to pump. I can't get piston out because of long pin on Lift/PTO control springs mechanical arms. Any advice on getting piston out or removing cylinder is appreciated. Here's two pictures...
Thanks.
Thanks.
