Rejuvinating Old Files
guido
Hello,
I have not cleaned my files for 20 plus years. At work always cleaned them wit a card file. I have no clue of its whereabouts. Here is what I have used. A piece of flattened 3/8 scrap copper, then a stiff stainless brush. The copper is soft so as you use it will get grooved and dig the debris out. They came out fairly clean. then I folioed with the brush. Now they cut real well now. I just wanted to pass it on.
Guido.
Get a good file card. Try "brownells.com" the gunsmithing place. Clean it and use some sort of rust preventative and put it somewhere it won't be touching other files or metal. A good file is something to be careful with these days when good files are not only expensive, but hard to find.
I just watched a video on this. The guy used the copper pipe trick, then soaked the file in a 10% solution of sulfuric acid (drain cleaner) for an hour. Then neutralized the acid by dipping in a solution of baking soda and water. File came out clean as a whistle.
There is a company out there someplace that will chemically clean and sharpen old files. It's not cheap, but there are some files you simply cannot get any more. I can try to find the name if anyone is interested. I think they'll re heat treat too
Funny I just found this Post, as I was thinking yesterday how to restore the cutting edge on and old, old special shaped file that is not available anymore.
Old timers use to soak them in some type of acid for a short while. The acid would remove some of the metal file and leave a sharp edge on the teeth.
Thanks for the advice on what type of acid to use.
(quoted from post at 11:33:57 11/15/16) Funny I just found this Post, as I was thinking yesterday how to restore the cutting edge on and old, old special shaped file that is not available anymore.
You can try degreasing them and going at them with a file card for staters. The acid they use is pretty stout stuff and probably not something you want to play with in the house. I believe it's a sulfuric acid but they use some sort of vapor set up, not just dunking it in the acid and hoping for the best.
