glenster help !
dr sportster
Went to the pic a part and got a new third brake light for my Cadillac . Could not figure out the wire connector and cut wires . Went home and tried to unsnap connector on brake light in car . What is the trick to un- snapping these GM connectors?
there will be a lock tab on the connecter. squeeze the connecter halves together slightly and push the lock to release, then wiggle the plug apart. sometimes you need a small pair of needle nose to help pull them apart, and a small screwdriver can help to release the lock.
