Bought a new 20 gallon bladder tank to replace my 14 gallon bladder tank, that is still operable but starting to show some rust from condesation arount the seam. What is the best way to get the flexible plastic line free from the 1 inch pipe adapters. Also what is the best way to get it back on the new tank adapter fittings. Tried pushing the adapter into a section of the black flexible pipe at the store and it didn't look like it will go on unless the plastic pipe expands a bit. Once on the adapters. hose clamps secure it to the adapters.
Thanks for all the advice in advance,
Bill
ps.
Solved my water pressure and water loss. Replaced the flapper in one of the bathrooms and the flapper and fill tube in the other. Problem solved. Thanks for your help on that one also.
Bill
ps.
