Bought a used maytag (whirlpool) double oven gas stove. After installing the lower oven would not work---HSI glowing bright with no visible damage but won't activate gas valve. Top oven works ok.
Switched the HSI on the two ovens and now bottom oven works and top doesn't.
Is there a simple diagnostic to check HSI? What exactly allows the gas valve to open? I once had a stove with a cracked HSI and it still worked----a bit slow but it did work.
