Finally got or made some time to expermit with the well pump cycling problem. I also checked the bladder tank both with the pump just having finished running and when pump had been turned off and pressure had dropped. Could fell that after the pressure had drained off the tank was empty. Let the bladder tank fill up, noted pressure, shut off valve coming from the tank and pump to the rest of the house. After 3 hours had not lost any pressure. So in my uninformed opinion that pretty much ruled out a problem with the bladder tank or the well itself. When pump did run pressure would be down. Went to the guest bathroom and shut off the line to the toilet tank fill. Left the master bathroom valve on. Opened the house valve and turned the power back n to the pump. That seems to have stopped the loss of pressure causing the pump to cycle on every hour and a half or so. Going to pick up a flapper valve for both toilets this week and replace at least the one in the guest bathroom, I think it's about 30 years old.
Any thing special I should do when I replace the flapper? I'm going to drain the tank naturally and get rid of the small mout of sand in the bottom of the toiet tank. This is a very sandy area and I'm told this sand is a common problem around here. Disturb the sand and it never seems to tottaly repack tightly. I live in Mid Mivhigna north of Bay City.
Thanks for all of your help,
Bill
Bill
