I have an old spa at my house in Mexico. It is hard wired from a 30amp, 240v breaker box 60' away. It is a 3 wire run (black, red, white). When I first got it I disconnected the electrical heater, and simply ran the water through a 150k propane spa heater for better heating times. Everything worked great. Know the whole power board is fried. I tested the 240v water pump and it works, but now I need to make it safe. I do not have a bare ground wire, only a white neutral. If I install a breaker box, put in a 2 pole 30amp 240v GFCI breaker, use the curly wire to the neutral board (wired from the incoming neutral), then take the neutral from the breaker, and the two hots coming out to the two pole breaker I then would have a protected GFI circuit correct?
