Well Pump Company
guido
Hello,
Some of you may be interested in learning more about well systems. Lots if misinformation at times confuses the topic. Here is a link, I have two bladder tank from them. They patented the first bladder tank system.
They have videos as well,
Guido
Well Tank Company
very interesting operating instructions------
Adjusting Precharge Before Installation
Step 1.
Remove protective air valve cap.
Step 2.
Check precharge pressure (pressure should be + or -
10% of the 38 psig factory setting).
Step 3.
Release or add air as necessary to make the precharge
pressure 2 psig below the pressure switch pump cut-in setting.
(Example, if you have a WX-202XL with a precharge of 38 psig,
and you have a pressure switch setting of 30/50 psig, adjust
precharge of your WX-202XL from 38 psig to 28 psig.)
Step
Bladder tanks have been a great improvement in well water systems. Not only in the pressure control.
Where we had lived for over 40 years the well has an iron bacteria, that's where iron is dissolved in the water. When the water comes into contact with air, the dissolved iron turns into an iron past in the water, which makes a big mess of the whole water system, and every thing the water comes in contact with. Changing to a bladder tank solved 99% of this problem.
Dusty
Hello dpendzic,
Yea! Coming from the source, it makes sense they are right,
Guido.
sorry Guido--I wouldn't have posted this if I had read your last post on the other thread.it is really easy to get the cut in and cut off terminology confused as I myself have done at times!!!
Hello dpendzic,
No apology needed, I had it backwards...twice! All is well....
Guido.
Hello Dusty MI,
The video I saw showed how they made the tank and how they sealed the bladder,
Guido.
