American Bosch injector tester
I have an American Bosch injector tester model TSE 7722D that I purchased at a case dealer auction many years ago, I only have two fittings for different injectors for it. I ran into injectors that don't fit either size and I was wondering where I could get a full set of adapters for the tester?
Thanks,
Brian
Most pop testers come w/ 2 "standard" lines..
Are you looking for an ermeto fitting?? The sealing surface is lower in the hole..??
The line goes down IN the fitting??
Just google it or make your own..
