So I was trying to pull a gear off the other day with a bearing separator. Hopefully this isn't too complicated/confusing. Everything was peachy until one of the 2 studs that went down to the bearing separator sheared off. It is a rod with one end threaded that goes on the outside of the bar that has the threaded screw (that you turn to pull the bearing off) and the other end has 2 different threads to go into 2 different bearing separators. The threads are stepped. I can try for a picture tonight if it doesn't make sense. Need to know what this might be called and where I might be able to find parts.
Thanks.
Thanks.
