1720 DIESEL FORD TRACTOR JUST CUT OFF AND WILL NOT CRANK BAC
Redspur
New User
Hi every one
I need help !! I have a 1720 Ford diesel tractor with about 08875 hours . I bought it new . Today I crank my tractor up it had been running a few minutes and i put it in reverse and it cut off and will not crank back up . The tractor was running fine with no problem that i could hear or see . It has a full tank of diesel fuel bought yesterday 9 - 9 - 2016 . I did not crank it until today 9 -10 - 2016 .
The battery is fully charge and the tractor was running very good untill now . The starter cranks good but the engine will not start !!
It did just like a gas engine when you turn the ignition off while it is running.
Any and all help would be appreciate !!
Hello redspur,
My first thought is a bad batch of fuel. Chech the filters for water. Also check for water in the tank.
Could have been stirred up during fueling?
Guido.
Hi, I had a C 530d some yearsback. I shut it off for
lunch and when I went to start it, it cranked over
good but wouldn't start. After a lot of 'try this, try
that' I found the the rack was stuck. I took the top
off the inj pump and with screw driver , a little
bump and the rack slipped open. Ed Will Oliver BC
