re your post below
old
09-08-2016 13:18:39
#1 sounds like the wrong solder. You need Rosin core solder for wires. I have solder so much stuff over the years I hate doing it any more but I was a Navy E.T.
#2 you need to tin the iron which means you melt some solder on tip so that will help heat transfer faster.
#3 clamp a heat sink on the wire just behind where your going to solder . A set of hemostats work well for that. BTDT to many times
[Reply] [Send Email]
bill b va
09-10-2016 05:34:07
Re: Soldering wires in reply to old, 09-08-2016 13:18:39
Old if you have done that much soldering you must have heard of using salamonac (sp) to clean soldering irons . by the way shouldn't that be soldering coppers and not irons.
old
09-08-2016 13:18:39
bill b va
09-10-2016 05:34:07
