repair of end less baler belts
brylee
New User
I have a Vicon Baler Wrapper which has endless belts.
The belts have been joined diagonally , so to re-join it I will have to cut about 8 inches out
would I have to add that amount back in or would it be ok to run with one belt a bit shorter.
8 inches is too much. You'll have to put in a "Dutchman's splice" and add a piece back in with two laces.
Can't run it 8" shorter than the others. It probably wouldn't fit anyway. Is the splice coming apart? If it's just stretcher I suppose you could cut it somewhere other than the splice and shorten it that way.
