OT: Computer problem
Slowpoke
I recently had cable internet installed in the house. For a few days I used a laptop with ethernet cable, no problems. I then connected by cable an HP 061 desktop which has not been used in several years. Running Windows Vista Home Premium, several sites including Ebay and THIS site are opened, but then are blocked by an Internet Explorer popup saying "Cannot open internet site (Ebay%jfruyr434hbdn87&%5gehmotorcycles)".
"Operation aborted". On some sites including THIS one, I can cancel the popup and access the site, but never onEbay.
Also "Chrome" has made an appearance with asking and wants to download.
Any ideas?
Thanks,
Slowpoke
I would say you more than likely need to do all the updates on the computer having not used it for several years. Seems like I heard the older computers programs are no longer supported don't know if yours is affected. May be someone here who Knows.
Best of luck Byron
I agree. Updates could cure it.
BTW, I have a problem of my own. I set up a new desktop this week. I have our personal finances on Quicken on the hard drive and back it up to a flash drive.
I installed the Quicken program on the new computer and was successful in transferring data from the flash drive onto the hard drive. Now, I can back up data onto the flash drive, but I can't access it on the flash drive ON THIS COMPUTER. Works great on any other computer, my laptop, my wife's desktop, etc. From pulling it up on them, I know it's backing up OK on the flash drive, just can't pull it up on the new computer. Guess I'll have to call some techie on it.
Windows Vista is at the end of it's life cycle and will not work with Explorer 10.
I have Windows Vista on another PC and it (Explorer 9) will not work with some web sites. I can use Mozilla Firefox (instead of Windows Explorer) and all web sites work fine.
It has also been difficult to get Windows updates for Vista.
Yes, date and time are correct. Computer has been used only to play Freecell game occasionaly since 2011.
Vista Service Pack 1 came up when I checked for updates. It took about 45 minutes to install. Checking for prior Windows updates, installation of Service Pack 1 is listed as "Failed" shortly before I gave up Dialup several years ago.
But the problem of "Can't open website" still exists.
Well, if the laptop works and the desktop doesn't, then your cable internet connection must be OK. So the desktop must be the problem.
There's a good chance the desktop is infected with malware. Even if your problem isn't malware, browser technology has progressed a long ways in the past decade which could explain your errors. Do you get the errors accessing YT on both modern and classic views? YT uses pretty basic technology even on modern view, so I'm really surprised you're getting any sort of errors unless the PC is infected with malware.
Do you just use the desktop for web browsing? If there's no Windows-specific software on the PC that you absolutely need, the simplest fix is to do a clean install of some distribution of Linux. Ubuntu, Mint and Fedora are all good choices. It will cost you nothing, the PC will get updated to the latest technology, and any malware that might be on the machine will be gone. Loading Linux is the best way to breath new life into an old PC.
(quoted from post at 01:15:41 09/04/16) Vista Service Pack 1 came up when I checked for updates. It took about 45 minutes to install. Checking for prior Windows updates, installation of Service Pack 1 is listed as "Failed" shortly before I gave up Dialup several years ago.
Thats a good reason to move to firefox as your web browser. I find it works well.
I downloaded Firefox but it only loads 99% and stops. I can't find it installed anywhere on the computer. The computer is running IE7, but it won't let me upgrade to IE9. It always pops up with "operation aborted". I get the same box on this site but I click close and it allows me in.
I have a book "Running Linux" and it looks like I have to know Dos to use it. All kinds of symbols and small & capitol letters. I thought it was similar to Windows. I also have a disc of Red Hat somewhere but am afraid to try it.
Linux is based on UNIX, not DOS.
It is true that not too long ago, you needed at least a rudimentary understanding of UNIX to install and run Linux, but that's not really the case these days. Most popular Linux distributions can be easily installed with no knowledge of UNIX, and the graphical user interface, called a "Desktop Environment" (DE), isolates the user from the underlying operating system. Most distributions offer more than one DE. Fedora, for example supports GNOME 3 by default, but it's a simple enough matter to install KDE, Cinnamon or MATE. Compare this with Windows, where you're pretty much stuck with whatever user interface Microsoft thinks is good for you.
There are a few differences between Windows and Linux that the user interface can't mask. For example, Linux doesn't support the anachronistic DOS drive letters like Windows does, and the directory path delimiter is the forward slash rather than the backslash. But you'll quickly get used to these nuances.
Most Linux distributions are available on a "live" DVD, so you can fire up the distribution and get a feel for it without actually installing it.
The original Red Hat Linux was superceded by Fedora over a decade ago, so your Red Hat disk is probably quite old. (Unless it happens to be Red Hat Enterprise Linux, which is an entirely different matter.) It's best to download a current distribution; you can find them all at <a href="http://distrowatch.com">Distrowatch</a>.
(quoted from post at 14:19:44 09/04/16) I have a book "Running Linux" and it looks like I have to know Dos to use it. All kinds of symbols and small &amp; capitol letters. I thought it was similar to Windows. I also have a disc of Red Hat somewhere but am afraid to try it.
It is similar to Windows, and you don't need to know how to use Dos to use it. Although I can use the command line, and do because it's a shortcut for some things, It's been several years since I would have had to at all. And if you have a Red Hat disc around, you don't want to try it as stated, it will be old. As long as your computer is compatible, which most are these days, you can make a disk (free download, use a cd or usb), make your computer boot/start from it, and try it out BEFORE installing it. Don't like it, restart, remove disk, back where you started, no changes.
Not everything works, but a lot of stuff does. HP printers are easiest, I use Canon, some don't work, some require work because not everyone supports it.
Download this. https://rufus.akeo.ie/ And if your computer is relatively new, or at least with say 1GB ram if you know, download this, large download, may take a while, and careful if you have a low data cap. http://ftp.crifo.org/mint-cd//stable/18/linuxmint-18-cinnamon-64bit.iso Plug in a usb drive, start the first one, the line "create a bootable disk using", change the dropdown to "iso", button to the right of that, click it and find the mint file you downloaded from above and select it, click start, wait. Then, reboot your computer, and you need to make it start from USB (that will vary, may need to look it up for your model). It will either work or it won't to try out. If you don't like the look, we can suggest another that looks different, but this is one of the most popular ones.
You can use a cd/dvd disc if you want, different steps, if that doesn't work.
If you like what you see after the trial run, it's easy to install, only one step to be "careful" of, the "partition" step to make sure you don't erase Windows if you don't want to, very easy handful of questions to answer (or select what's already selected). But you can install it and keep Windows exactly as it is. When your computer turns on, you get a selection of the new, or Windows, restart to switch between them.
Plain Ubuntu looks different than Windows, although not hard, I would not suggest it if you want something similar to Windows. What I suggested has a bar at the bottom, "start" like button, etc. Of course programs have different names. But, Firefox, Chrome, etc. can be installed. Good typing, photo and video editing, etc. are available.
(quoted from post at 16:55:19 09/03/16) Windows Vista is at the end of it's life cycle and will not work with Explorer 10.
Yes, go with Firefox. I'm still running Vista on this desktop and having NO issues.
The old browsers relied upon java and quicktime.. both of which had security problems. and as the problems were discovered, web sites moved to more secure versions to correct the problems.
Therefore your old internet explorer will not work correctly on sites that have the new secure software. you will need to download a newer browser.
Microsoft has stopped all support for internet explorer and moved on to EDGE.... Internet Explorer does not work on newer web sites.
Firefox and Chrome are the better choices. Since google collects all your data, I stay away from chrome and google products as much as possible.
Any computer that hasn't been used for "several years" is likely so far outdated as to be junk. Desolder the components off the boards and make some jewelry or something useful. You will find useful strong magnets in the hard drive.
