(quoted from post at 17:16:51 08/22/16)
If you wear eyeglasses, most of those earmuff types won't fit tight enough to give the protection needed.
This is what I do, always with me. Every time I run a tractor, all day in the hayfield, pounding stuff in the shop, they go in. I don't like the foam kind, my hands are always greasy, they are dirty the first time they go in. With the kind I use, sound is muffled, but I can still hear if something is "off" with a tractor or equipment.(quoted from post at 04:10:19 08/22/16) I find the ones on a string or line, that you keep in the round container are very handy, I keep a set in my left front pocket at all times, never know when you need them, I value my hearing, so if I have to walk out into the steel fabricating shop at work, or for some other unexpected reason, I've got hearing protection with me at all times. One pair will last a long time, though I am not sure what the O.S.H.A rules are on this type in regards to disposal, I had one set I carried for 15 years. Blue on a blue string and a solid design, not the barbed looking ones so common now.
