Loud Door Bell
Steve@Advance
I've been asked to install a door bell. This is for a homeless ministry I do some volunteer work for, so this is coming out of my pocket...
What they need is a loud bell, tone, noise, something they can hear anywhere in the building. This is not a large building, they just need to hear if they are in the office at the other end, maybe 40 feet away.
What I have is a 12 watt, 8 ohm paging horn. Any practical and economical way to generate a tone that could be connected to this horn?
I've been looking at bells, and Viking amplifiers, but looking at spending $75-100 to go that way. Any ideas?
Thanks!
I've used a wireless doorbell extension to add a doorbell in the basement. A small sender installed inside the original chime and the extension was battery powered. I'm not sure what the range was. Check a local big box hardware store or Amazon.
How about a smaller fire alarm bell? As a matter of fact I think I have one at home that you could have if it's loud enough. I'll try to remember to check when I get home.
Go to a local animal shelter and get them a poodle type dog. Any little knock on the door and ours goes CRAZY !
Bob has the answer. Make sure you get plug-in receivers. Some receivers are battery operated, and they are "Listening" constantly, and need the batts replaced about once a month or so. The pushbutton battery lasts for years.
Go wireless. Get the "ringers that plur into any wall outlet. Use where desired. Two minute install of the button at the front door.
Neighbor put in a wireless doorbell. Whenever someone rang his doorbell button, it also rang the bells in the houses on each side of him!
Thanks everybody, I went ahead and ordered the plug in wireless with 3 remotes.
That is much easier than running wire!
I didn't realize they made them with multiple remotes, that will work well for what's needed.
Thanks again!
Let us know how it works out, Steve, the doorbell with two receivers made sense to me, and I couldn't believe some of the other posts suggesting using a firebell, or what ever, 'cause I'd think all that noise would be the LAST thing you'd want when dealing with distressed folks looking for help.
God love you for helping those in need, I try to do the same, but but probably don't do enough.
That's what I did; old trumpet horns from a diesel truck hooked to 12 volt battery & pushbutton. Scared several women out of their skin but never failed to be heard in my garage or apt. above it.
The remotes are a sensible way to go. But did anyone consider that a 24 volt doorbell circuit is 60 Hz? Run it through a resistor so you don't blow your 12 watt horn and you're good to go. 60 Hz is annoyingly low, but you can kick it up an octave by running it through a full-wave rectifier bridge; add a series capacitor so it's ac-coupled and you have 120 Hz.
It's been a while since I fooled with mine, but I think there are dip switches in them to change the frequency. The guy in the middle is the culprit.
