..and in addition, resistor value is unknown! If 0.1 Ohm, it makes no difference!(quoted from post at 20:07:36 08/11/16) Sounds like it NOW indeed has a correct full 12 volt coil on a 12 volt tractor. Maybe in a past life it was 6 volt and they converted to 12 using the old 6 volt coil so the ballast was added then??? I'm not all that surprised it can still run okay, but the real test comes when she's placed under a heavy load. Summer hot weather starting isn't all that difficult either which is why it can still start good even though spark energy is less then if wired correct. Hey if it ant broke don't fix it lol. If it doesn't run good under a load or is hard to start next winter then maybe the ballast can be removed???
Keep cool down there Rich
John T
