What tool is this?
Gumby
A friend gave this tool to me. He thought it was used for sheet metal work. The "nippers" are reversible and replaceable. Is this used for crimping some sort of seam?
Here are the pics.
I am ivor from uk and I don't know the tool is for but I will make a guess and say is it some sort of animal foot trimmer???
sheetmetal workers use a similar tool to bring the duct sections together to install the drive and couple the sections together.
I'm with Ivor. Looks like a farriers tool to me. I have seen them used for crimping Oteker brand hose and CV joint boot clamps too.
My father had what he called a horse hoof trimmer and only one side was sharp, the other was flat, but there are probably different styles. this tool does not look very old when it has replaceable cutters, it wasn't made by a blacksmith.
not for horses hooves as the bite is very shallow. too shallow and too narrow for trimming hooves... could be for nails, ears, or something else.
but I think the duct crimping or other is probably the way to look.
I have trimmed alot of hooves and shod horses for years in my younger days. Those are not for that. I am not familiar with sheet metal work, but they look like some sort of seaming tool for that trade.
I believe they are Grozing pliers , similar to tile nippers but used on glass to trim the edges when fitting lead light and stained glass panes . The replaceable and reversible cutters bear this out .
Look like antique end cutters or nippers to me. Channel Lock makes several types, lengths. I have several pairs that I mostly use for pulling fence staples out because I can squeeze hard enough to get a bite, not too hard to cut through, and can roll them to pull old staples. Are still enough to cut horse or cattle fence in a pinch if actual fence pliers aren't readily handy. Channel Lock makes them too. Can never have enough pairs of either. Let's see if Channel Lock has a website.
Mark
Here you go
These too. Gotta have a pair on every tractor, two or three out in the barns, a pair in the tool shed, tool boxes, tool chest, under the seats of the pickups. Can never have too many pairs of these. In a pinch can hammer in fence staples too. Not real good, but can.
Mark
All in all, at least 10 pairs of these
