Danny Prosser
Morning everyone. Hope all of your day has started good. I've got a problem with where my welder is located I can't get my trailer close enough to weld on it. I think I know the answer but wanted to double check. It would be better to make my leads longer than it would to make the plug in longer correct? I can't put the welder anyplace else and trying to figure something out. Naturally the place that I need to weld in on the front and there's no way to pull in close enough or back in either. It's a miller stick welder. When I get moved out to my land in a couple of years I won't have that problem. I've had plenty of time to plan and build my shop out there as to not have that kind of problem. It's funny my dad used to say before he passed I don't understand why you built a pond and shop before you moved out there. I told him because I had plenty of time to plan them and build them like I wanted so I was doing what I could until I can afford to move out there! Thanks for suggestions.
