trailer tires
MF294-4
Trailer had car tires on it and I put a new set of Trailer tires on it 2 years ago. Can't find 15 inch car tires anymore. Someone said p tires are illegal anyway. ??? Chineese tires are starting to seperate the treads. Only pull it 20 miles every other week in the summer with a 1000lb mower on it. Surely there has to be a better tire solution than these Chineese tires.
I find 15" available on Amazon and eTrailer. 202 hits on eTrailer!
https://www.amazon.com/2-Pack-Trailer-Wheel-ST205-75D15/dp/B00IEYDSHQ/ref=sr_1_6?ie=UTF8&qid=1469457160&sr=8-6&keywords=205-75-15+trailer+tires
http://www.etrailer.com/dept-pg-Tires_and_Wheels-pc-15_Inch.aspx
See if you can find some bias ply LT (light truck) tires that will fit your wheels. They are limited to narrow widths, so won't work with wide car wheels.
The LT tires are built to higher standards than the ST (special trailer) tires which have proved to be troublesome.
Look til you find some 15"lt radial tires. Trailer tires are generally not good tires. Another option would be to change the rims for larger tires as the outer diameter is not that much different. You should be able to replace them with rims from a junk yard for just a few dollars. Around me they run $15-20/rim and tire. Ford ranger, explorer and v-8 mustang rims should bolt on if you have 5 on 4 1/2 standard trailer bolt pattern.
